I have a JD Humanoid robot, and I would like to control it using a remote control. Is it possible to control my JD Humanoid with a Steam Deck controller?
svorres
Can I Remote Control My JD Humanoid With A Steam Deck Controller ?
JD Humanoid
by EZ-Robot
Servos
24
UART
3
ADC
8
Digital
24
Joystick (Direct Input)
by Synthiam
DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback.
Joystick (Xinput)
by Synthiam
XInput joystick skill for ARC: maps Xbox controllers to movement, servos, triggers, vibration, variables; supports analog inputs and scripts.
Requires ARC
v16
Movement Joystick
by Synthiam
Analog joystick UI to control any ARC movement panel via mouse/touch-configurable dead zone, max speed, center-reset for smooth robot motion
Requires ARC
v6
Yes, you can control your JD Humanoid robot using a Steam Deck controller. The Steam Deck controller can be configured to work with ARC through the Joystick (XInput) skill, as it supports XInput devices like Xbox controllers.
Here are the steps to set it up:
Connect the Steam Deck Controller:
Add the Joystick (XInput) Skill:
Project -> Add Skill -> Remote Control -> Joystick (XInput).Configure the Joystick (XInput) Skill:
Devicedrop-down menu, select your Steam Deck controller.Add and Configure the Movement Panel:
Test the Setup:
Additional Resources:
If you encounter any issues or need further assistance, feel free to ask!
I feel like you should be able to, please check out the Joystick Direct Input skill: https://synthiam.com/Support/Skills/Remote-Control/Joystick-Direct-Input?id=16087
