Kondo KRS ICS Servos icon Kondo KRS ICS Servos — Control Kondo KRS ICS2/3.5 servos via EZ-B UART; experimental, untested. Supports chaining, virtual servo ports, Release() and Servo() commands. Try it →
Xl Rover Prototyping Community Feedback
ANT is doing a great job getting the first proto of the XLR6 ready to send to me to start working on so for the sake of planning I would like to listen to the communities ideas for a rover kit and rover base. The EZ Robot kit is a great place to start so we aren't trying to replace Roli. This is for the next level kit , more ridiculous add ons can be made later. I will share some of what we have in mind so far. As always all our projects are being developed for use with ez robot Ezb v4 but you can still use a v3 in them.
Rover kit , that's a top and bottom to make the whole Xl rover
  • misc parts like wheels
Rover base only, that's the bottom half of the Rover frame with wheels and a flat tray on top all molded from 80A shore urethane plastic
#41
I love the concept of a military or stealth theme because of the rugged feel. Agian just napkin sketches for the tops. A center sphere is common in both designs and a feature I am sold on that I simply only see in professional robots and military / industrial equipment. In both cases a ultrasonic rangefinder and camera is in the sphere. I want it fairly large so addition sensors , stereoscopic cameras or other sensors can be utilized in the same enclosed pan / tilt assembly.
Ok so I really needed to get suspension components that are standardized enough to be purchased anywhere in the world but also available at a low cost. Some aspects of chassis I won't make public but others are important right?:) i will measure these units and then model them as a 3d stl. The rest of the suspension length and shape depends on these numbers. Here are pics of the shocks. They are in fact oil filled and use a coil over progressive spring. At this point there are various angle choices and options to have either one or two shocks per wheel.
@Josh I really like those mini shocks and they are oil filled also, they look like a good quality and sturdy shock. Very nice indeed :-}
#44
@josh - Are those offroad R/C shocks? What brand is that? HPI usually has purple anodized aluminum parts.
South Africa
#45
Where did you do all the 3d designs on
#46
Hey, the shocks are unbranded and direct from china. They do resemble hpi so maybe they are the same , i found pictures where they literally look identical. I wanted to use a format that gave the end user easy upgrade options from a local hobby shop or online provider. They are compatible with alternate springs and heavier weight oils as well. The plan will allow for swapping of shorter 80mm shocks as well. That was one of the limiting disadvantages I saw in completely proprietary spring suspension like in dagu wild thumpers
#47
@Josh More than likely they are the same shock as the hpi ones. Lately I have been ordering parts and pieces off of Ebay from China, I cannot beat the prices, none of the stores around here even come close on the price and most of the time the shipping is very cheap or nothing at all, now I don't understand that at all.
#48
Muhammad , i started using 123d design which is more basic but user friendly and produces stl objects easily. It's a good idea to download and start learning blender and Netfabb as well. You can start a object in one program then migrate it to another for creating complex curves objects you can only do with mesh. Take in mind I'm still new and I recently downloaded 3ds max but I'm still very new to it.
