TCP Script Server Raw icon TCP Script Server Raw — TCP server for ARC accepting EZ-Script, JavaScript or Python commands, letting controllers send commands and receive line-terminated responses Try it →
Wireless Controlled Servos To Ez-b V4
Wireless Controlled Servos To Ez-B V4
I have two servos which cannot be hard wired directly to the EZ-B controller. They will be located about 10 feet from the EZ-B and I can't run wires to them. These servos will be controlled by the script running in the EZ-B using information from the camera input. Can I use a wireless device like an xbee to connect the servos to the pwm outputs on the EZ-B? Has anyone ever tried this or has suggestions as to if it can work?
Ron
#17
I really didn't want to go the arduino route. I am VERY happy using the EZB and realize the great abilities of the unit. The size is my only problem.
DJ, thanks for the tip. I will be watching for the "secret" next week and will be putting in my order. By the way,,, LOL,,, my hair has gone gray already..
The EZB is the way I want to go. The Halloween project will use two units, one new and one from my "Lilian" robot. She will be quiet those two weeks in October. The additional unit with base will run the remote servos and now we can add more to the stand alone area using the additional I/O and features.
Thanks to All for the options and help.
Ron
P.S. Where can I get a plug for the power connector on the back of the EZB. ((not the base ) I rather not use the power shell)
#18
I agree the easiest route is with two ez-b units. The most expensive part of alternative approaches is usually the radio modules. Xbee units are not cheap and if you already have them that is most of the expense part. If you have an arduino and know how to program it the code to control a servo with serial commands is not rocket science, although it would take a bit of work. In reality programming is not even necessary if you don't mind spending around $20. Pololu makes a servo controller that can be configured to take serial command and control a servo. It is a six-channel Micro Maestro . The coding on the ez-b side to use the micro maestro is a bit of work, but very doable. You will most likely be happiest with two ez-b though. I am also looking forward to any deals that may be coming.
