Auto Release icon Auto Release — Auto-release servos after inactivity: set EZB board/ports, choose 1-60s delay, add/remove ports, pause and view status. Try it →
You could get a replacement JST connector and a JST crimping tool, but since you can get a replacement battery for $10 https://www.amazon.com/dp/B016DD1GT6 (although several weeks for shipping, or from EZ-Robot faster, but more expensive and more expensive shipping).
Other batteries may be available on Amazon or local hobby shop. The specs you are looking for are: 1300mAh 2S 7.4V 25C with a DEANS connector (DEANS connects to the robot, JST to the charger).
This one would work too... https://www.amazon.com/Zippy-Compact-1300mAh-Battery-XT-60/dp/B00WFHM53Q free 4 day shipping for Prime members, although they are currently showing just one in stock.
The cheapest JST crimp tool I can find is ~ $14 https://hobbyking.com/en_us/hobbyking-jst-sh-connector-crimping-tool.html you might just want to replace the battery (also crimping new connectors on the batteries can be tricky. If you short the wires, they get explody...).
If you have a local makerspace, they probably have a crimp tool you can use, which changes the math....
If you post a picture you might be able to do it with a small slot screw driver and a little finicky work.
