Yes, it'll work. Maximum voltage is 14 volts. Ideal voltage is 7.5 volts which is 5 alkaline batteries or 6 rechargeable ones. You can just solder wires across a few of the battery cases if you want to bring down the total voltage.
got it thaks!
so is my plan of a 7.2v battery pack not enough juice? should i get 7.5v battery?
also are 8 aa batteries putting out 12v? i want to confirm im not going over the max 14v for the ezb
Your 7.2V battery will do fine.
Are you using rechargeable batteries (which are 1.2V each) or disposable ones (which are 1.5V each)? 8 rechargeable AAs combine for 9.6V while 8 disposable ones make 12V. Either way, you're within the range the EZ-B can handle.
lol, one more thing....what size is the power connector? i can get the battery case from radio shack and they also sell power connectors but hwta size is the ezb one?
will this one work>
size m connector
lol, duh!!!! simple math.....sorry just way excited.
and thanks man for the quick replys
You'll need a 2.1x5.5mm male plug. Tell the guy at Radio Shack it's for a CCTV camera.
love ya bro!
this is the spec for the above mentioned plug i found
Tip size: 5.5mm O.D.x2.1mm I.D.
i see the 2.1 and 5.5 in there is this good to go?
COME ON CHOYSTER I NEED ONE MORE ANSWER PLEASE!
