PWM Slider icon PWM Slider — Slider to set EZ-B digital PWM for motor speed or LED brightness; shows duty-cycle, stop button, and board/port selection. Try it →
Where Is The Getting Started With ARC Mobile App Info?
I don't want to build a custom app, just want to use a prebuilt one.
I figured out how to do this and to connect and run my JD from my iPad but couldn't find instructions.
For example, when I launch the ARC mobile app on my iPad I need to be sure to have an internet connection so that I can download & install the public app.
then needed to change the settings in my iPad to the JD WiFi so that I could scan for it and connect to it
Then I needed to push the "back" button to return to the previous screen... this was obvious to me
My question is, is this documented somewhere?
The learn section has tutorials and information to get started. Once your robot is assembled, check the activities tutorial in the learn section. Additionally press the question mark on every control to get running. Sounds like you're already there! Have fun:)
