EZB Connections icon EZB Connections — Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices. Try it →
Spain
The Futaba S3003 servo is standard, Stall Torque (4.8V): 44 oz / in. (3.2kg.cm) Stall Torque (6.0V): 56.8 oz / in. (4.1kg.cm). If continuous rotation has the same torque than the normal servo. Just take into account when using continuous rotation wheel if the wheel is bigger gains forward speed but lose torque.
