User Defined Function Example icon User Defined Function Example — Add custom EZ-Script functions in C# or JS; intercept unknown calls, parse parameters and return values via AdditionalFunctionEvent. Try it →
Vexplorer Tread Kit
Is anyone familiar with the Vexplorer Tread Kit? I have one that I was thinking of upgrading my omnibot with, but wasn't sure if it would take the weight. Keep in mind it will have a larger battery (12V) and two guns for arms. So there will be a slight weight increase over the original weight. Any input would be greatly appreciated.
Thank you,
check out my omnibot project it uses it,handles more the 150 lb load if using vex high torque motors each motor torque is about 35 lbs each and using 4 of them
my omnibot project
Cool! I got my set in today and they are fantastic! I can't wait to use them.
do have to upgrade the motors if you want higher torque
