Sorry, I found what I needed. It turns out I found an H-Bridge available for my project. Sorry about that.
RoboticsMaster
— Edited
MP3 Trigger
— Serial MP3 Trigger for EZ-B: plays MP3s from mini‑SD; configurable port/baud. Deprecated-replaced by EZB v4 streaming audio. 3rd‑party.
This is the one I use, which is from the same place, and cheaper.
Drives the Omnibot motors without a problem but is only rated at 1.2A (higher for short pulses).
https://www.sparkfun.com/products/9457
here is a very common one rated 4 amps and 2 amps continuous on ebay its about $6
l298 dual h-bridge
and one rated at 3 amps little higher price and 5 amps peak 3 amp continuous dual h-bridge
I HAVE ABOUT 10 different types of H-BRIDGES will be doing some testing on them with EZB once i get back from my work trip
I test all designs ,sensor ,h-bridges ,circuits and a lot more NOT easy for the average robotic maker to do it,mostly because of the high cost to stock and buy all types Second since i am electronic engineer i also design my own h-bridges and sensors from scratch
Thanks robotmaker. I recently found a L298N h-bridge on ebay that was very close to me for $13.00. Thanks for the advice though. I myself am a very experienced robotics engineer myself, focusing in humanoid robotics. So far my current research platform I'm working on is called Project SIHRO. You can check him out here: https://letsmakerobots.com/node/33846
I was offer a job as a robotics engineer ,because of my work on sensors in california ,but turned to down because to far to go plus house change
I just retired early from my job to work on my robots and make more patent ideas
WHERE i work i design and make very high precision test equipment ,mostly called the sensor man at work,also i design my own servo's
That's pretty interesting. Very nice to meet you, robotmaker.
any designs or help just ask ,its free
