Graphy icon Graphy — Plot live data with ControlCommand scripts: multi-series charts, many chart types, legend toggle, add/remove series, export graph data to CSV Try it →
Sphero - Default Bluetooth Connection Pin
Found out recently that the default Bluetooth Connection Pin for all Sphero's to connect to a computer's Bluetooth is: 1234. Tested on V1 and V2 Sphero versions.
When you initially make the connection from the Sphero to the computer's bluetooth, you can choose NO PAIRING CODE, similiar to the Wii connection. When you try to connect in ARC using the Sphero connection button, then the OS will ask (with a balloon pop-up) for the pairing code, which is 1234. Enjoy
That's good to know - to prevent this valuable information from potentially being lost in the forum, would you mind creating a tutorial and linking it to the sphero control? That way your information will show up when people view the sphero manual page. Here's the link to create a tutorial: https://synthiam.com/Tutorials/UserTutorials
Will do this week. Thanks DJ.
