PWM Servo Feedback (ADC) icon PWM Servo Feedback (ADC) Add ADC positional feedback to hobby PWM servos via minor mod to EZ-B/Arduino; enables real-time position readout, calibration and puppet mirroring Try it →
Set Command In ARC Script
There appears to be a bug in the SET script command it causes a compiler syntax error when used. I'm using ToggleDigital as a workaround for now
Oh my! I will take a look at it tonight
Hello!
I looked at the command, and I can not duplicate the error. The command appears to work fine. Reference the script help along the side for the command example...
Set (digitalPort, [on/off])
Set a digital port state to either on or off
Example: Set(D2, OFF)
Just tried it again and it works now?
It's a simple piece of code to switch the Omnibot eyes on/off when you pass near his ping sensor
Ping_Wait(D2,D3, lower, 30) set(D12,on) set(D13,on) Ping_Wait(D2,D3, Higher, 30 set(D12,off) set(D13,off)
Repeat on
Perhaps it was the previous ARC ver which I can't test
Thanks for looking:) :)
