Blinkm icon Blinkm — BlinkM I2C multi-color LED control with slide dials for custom colors; supports SendI2C for custom I2C peripherals. Third-party device. Try it →
Screeching Ezb V4
Hi, have just unpackaged a brand new JD procured for our library education programme through State Library of Queensland, Australia.
Upon switch on, the EZ-B v4 cycles through it's lights and gets to the flashing blue as normal, but all the time makes a high pitched squealing/ screeching sound, which does not cease. There is no normal start up chime. It also does not appear to be connecting to wi-fi.
As i cannot see this issue mentioned anywhere in any forum threads or discussions, I am wanting to ascertain if there is an easy fix for this or if its a warranty replacement issue?
I have a video clip of the issue if it helps: thanks:)
video of problem
Whoa! That's a new sound:)
Use a Phillips screw driver and take the plastic shell off the ezb. See if the magnets have dislodged from shipping. One magnet may be touching the circuit causing a short.
Wow!
Wasn't expecting that....i wouldn't be surprised if customs, etc had a fiddle with that ezb4, because its never been heard or mentioned of before.
Hope you sort it out Alan.:)
