STL Doesn't Match Print
i printed the backpart of a lever servo,and i notest the file is not correct with the print? i notest some other parts doesn match.
JD Humanoid by EZ-Robot
JD humanoid robot kit - WiFi-enabled, 16 DOF with metal-gear servos; easy, fun, educational, available from the EZ-Robot online store.
Relative Servos by Synthiam
Synchronize servos by designating a master; slave servos mirror scaled (decimal/negative) positions with min/max limits and pause control
They match perfect. The image is a render of the stl.
i just notest there is another stl p23-01 is the good one. whats this file for?
thank you dj
