Intel Realsense D435i icon Intel Realsense D435i — Intel RealSense depth camera skill for distance detection, mapping, video streaming, and ARC NMS navigation telemetry Try it →
Roomba Port Rxd Voltage Output
I am eager to connect my EZ-B to my Roomba, but don't want to risk frying the board. The EZ-B tutorial states:
*Note Before Connecting To EZ-B:: Check the signal wire (white wire) with a volt meter and ensure you have zero volts from the Roomba. If you see voltage, you're connected to the wrong port. If you apply current to the the EZ-B from the Roomba, you will damage the D0 port and will require a chip replacement.
Here is the problem:
If I attach my multimeter directly to the port on the Roomba and check the voltage by connecting the negative black lead to the hole for pin #7 (GND) and the positive red lead to the hole for pin #3 (RXD), or any other hole in the port, I read voltage.
Holes #1 & #2 have a higher voltage (14 - 16 volts) because they are unregulated. Hole #3, 4 & 5 have 4.5 volts.
I have read on other websites - "Measure the DD, TX, and RX pins with a voltmeter. They should be either 0 or five volts."
Apparently my RX is not zero but closer to 5 volts. Does this mean that I can't use the EZ-B with this Roomba?
Can someone let me know if this is normal or not? If the voltage coming out of RXD from the Roomba absolutely needs to read zero volts, how can I remedy the situation?
Ah yes, our tutorial was worded wrong. It should be between 0 and 5 volts:)
Awesome! Thanks! That worry out of the way, I plugged it in and everything is a go. This is the best birthday present I've bought my son in years. Only problem is now he won't let me play with it! Sigh. stress
Haha!! Krempel, join the club:) I rarely get to build robots anymore. But, everytime i see something built by all of you, it's worth it!!!:D
