I just received in the mail today a REX motor With encoder and I was wondering if anyone knows where I can get a 5 pin plug and lead to suit the encoder pins on the motor
Steve
Steve
Hay Steve, I'm using this motor and encoder on the waist of my B9. It's pretty quiet and I really don't notice it. I have some pictures of it installed over in my project thread here on the ez robot forum.
That connector pin on the encoder accepts a common 0.1 Molex connector and housing. Found at places like Digikey, Mouser and Great Plains Electronic. Look here
https://www.greatplainselectronics.com/categories.asp?cat=70
I don't know if the crimpers you mentioned will work with them but I bet they will.
Hi Dave,
I intend to use the motor for the same application as you, (not really a coincidence
) I'm in the process of pricing a Molex crimper and some alternatives as we speak with my local Electrical Wholesaler. The Molex one is pretty pricey eek I need to check all the crimper's I already have too, I may have something that will do the job. I will have to wait for the crimp terminals from Element14 to turn up so I can do a test crimp.
Steve
I found an excellent low cost crimper, well, low cost compared to the Molex crimper. The Molex one would have cost me nearly $500 eek Hard to justify with the amount of work they will do. The other one is made by Engineer, model number PA09 $75 and they work a treat. Very happy with them.
Nice find! !
Where did the wheels come from that are shown on video ?
@rb550f, The wheels are standard 6mm axle trolley wheels that have been customised.
It needs the customisation because my robot locomotion platforms can move with great precision so I need to reduce wheel slippage to an absolute minimum else movement errors start to be a problem. This type of end wheel design helps keep wheel slippage down to a minimum.
Tony
