Prevent PC Sleep icon Prevent PC Sleep — Prevents a PC from entering sleep mode via a tiny, resizable control-keeps the system awake while minimizing UI real estate Try it →
Receiving And Using Uart Data In Script
I've been trying to receive data through the Uart port in EZB V4 and use it in a script. I've successfully been sending special commands to move my motor to exact points through a Kangaroo/Sabertooth combination and that's working great. I've even been able to read how many Bytes are in the buffer useing the below Script. This Script successfully moves my motor to position 113261 at Speed 10000 and returns a reading of 5000 bytes on the debug screen of the script. However I get no info at all when I look at the UARTRead line. Even is I did I don't know how to convert that info into any useful command in my script.
Kangaroo X2 Commands: P = Postion as read from an encoder on the motor. S = Speed the Kangaroo lets the Sabertooth move the motor at. Getp = Command to tell the Kangaroo to send the position it us reading from the encoder at any given moment. 0x0d = Carrage return
$Getp = "Getp"
uartWrite(1, 0, "1, p113261 s10000", 0x0d)
sleep(3000)
uartWrite(1, 0, "1, Getp", 0x0d)
Sleep(3000)
$x = UartAvailable(0, 0)
print("Bytes in buffer: " + $x)
$Getp = UARTRead(0, 0, $x)
print("Received: " + $Getp)
Basically I want to move my motor to a point and be able to trigger an event or another script before the motor gets there. I know I need a loop that reads the "Getp" info returned from the Kangaroo X2 but I cant find the right code to retrieve it through the Uart port and also be able to use it.
Any help with this code is welcomed. :)
That board number is your nemesis:)
Glad to hear it's good!
They sure are. I've done this same thing to myself a few times before. Sounds like you remember the last time you pointed this out to me. ;) Your like my personal Yoda.:P
