Reading And Using Servo Values In Tracking
Hello,
I have two cameras mounted on servos. They are set it up in tracking color mode (red). I have an 10 foot square area. The cameras are mounted in two locations (5 feet from a corner), 90 degrees from each other, against the outside wall . While tracking, I want to read the values the servos are at, and display the value. I know I can only read the information sent, not the true value.
I want to take these values and compare them to a preset value or coordinates.
My end goal is to track a Movement Panel to these two values.
My scripting skills are minimal to say the least, but can someone point me in a direction to find examples of these concepts?
I search around and know the "servo read" is somewhere, but I can't remember where.
Rich, Dave and Richard R, posted some information about this. Any ideas?
Ron R
#33
I forgot to mention these are continuous servos, D0 and D1. D0 values: forward =119, stop=109. D1 values forward=99, stop=109. The camera servo is D10.
@castlephelps Maybe you could load locations? instead of numbers?
Ron R
#34
I just want to bump the camera question from #32. I am wanting to use a reliable target or beacon. I want to determine if an onboard lamp is beter than a plain target. Lighting in the room will vary. Is Lidar the way to go?
Ron R
