3-In-1 IMU icon 3-In-1 IMU — EZ-Robot 3-in-1 IMU driver: accelerometer, gyroscope and compass support for motion sensing, orientation tracking and heading/navigation. Try it →
Questions With Video Feed
I have a Brookstone Rover, I installed the ARC on two laptops and I am having the same issue on both. The video feed works when it wants to ....which is hardly ever. I connect to the rover, create the movement panel, press connect then add the video panel and choose Brookstone Rover from the drop down (I have also tried reversing the order....so I would create the cam panel before pressing connect). It will actually show the image 1 out of 15 times that I try but I can't find out what causes it to work. Please help..
I was having trouble with two of my cameras. I did the mod as shown on D.J.'s tutorial site. The problems in the camera's disappeared and I never had problems with them since.
Basically, you Ditch the small little battery that is inside the camera. You get power from the EZB.
do a search for camera mod or something like that.
Good Luck!
Hope that this helped you.
Mel
