DHT11 Temp & Humidity Sensor icon DHT11 Temp & Humidity Sensor — Read DHT11 temperature and humidity on Arduino (signal pin 4) using EZ-Genuino_DTH11_Uno firmware; exposes $Temp and $Humid variables. Try it →
Resolved Resolved by Rich!
Questions Loading ARC
I download ARC on to my windows 7 laptop but when I try to insall it I get the following message EZ-Builder cannot be installed on systems with .NET Framework version lower than 4.5. What does this mean do I need to install highed version of something. Please help if you can.
You need at least .NET Framework version 4.5 and it looks like you don't have it.
You will need to download the .NET Framework and update before you can use ARC.
You can download it here
Thank I upgraded the framework and running fine thanks for the help and the fast response to my problem.
Don't forget to mark as solved if it's been solved:)
