PWM Servo Feedback (I2c) icon PWM Servo Feedback (I2c) — Real-time servo position input via Arduino ADC over I2C; supports Nano (6 channels) or Mega (16), configurable I2C address and scalable chaining. Try it →
You mentioned the program you are working with is C#.
If it is EZ-Script, than you will do this...
$value = GetPing(d0, d5) * 0.5
First you just need to figure out your scalar. And use the tape measure like my prevoius response:)
OK thanks DJ ,last question i need in inches
Hi @robotmaker From what you posted re: the specs on the LV-MaxSonar-EZ1T, (1 inch resolution and 0-254 inch range)... since that matches the ADC range of 0-255 then I would think that you could use the Analog Output of your sensor and an ADC port on the EZ-B.
The ADC Value control does have the option to type in your unit of measurement (for our visual purposes only) and a multiplier feature, which if set to 0 should represent 1 inch for each displayed number.
You may not need a scaler (multiplier) but if you do then the math is the same, just do the calibration steps @DJ mentioned using inches, and enter the scaler number in the multiplier field (i.e. 0.5 using @DJ's example).
Hope this helps.
they say that the analog ouput is not very stable,this sonar has the best accuracy of all the sonars pwm is very stable
