Full Screen Video Player icon Full Screen Video Player — Fullscreen overlay video player controlled by ControlCommand: play/pause/resume/stop; ESC cancels playback and locks new playback until unpaused. Try it →
Out Of Box - Bluetooth Light Broken?
Hi guys,
Just received my kit, plugged it in, but the bluetooth light isn't on or flashing. I've done the suggested tests with a multimeter, everything was okay there....anyone have any suggestions?
I was able to pair the controller, but that's as far as I can get. I'm unable to actually connect to update firmware. (I've went over the COM Port details as well to make sure I was connecting to the right port, and I've also ensured I am running an MS bluetooth stack. Also, when trying to connect for the FW update, the flashing red light would turn solid for a few seconds while attempting the connection, then I would get the:
"Attempting connection on COM6 Comm Err: The operation has timed out. BbytesToExpect: 1
Received: Disconnected Connection Failed: System.Exception: Controller Not Responding at EZ_B.EZB.Connect(String hostname, String tcpPassword) Disconnected 17/02/2013 8:27:36 PM - Connection attempt error"
Any help would be greatly appreciated! I wanna build a robot!
Thanks, Mat
In the picture you posted the Bluetooth light is on. Can you clarify this? Have you done the firmware update yet? You can try power cycling . remove power and plug back in and wait s few seconds. Bluetooth should blink.
