TCP Client icon TCP Client Telnet-like ASCII TCP client for ARC: connect to IP:port, send ASCII, view raw or HEX server responses with local echo Try it →
Openai Dall-E Skill Deprecated
The "OpenAI Dall-E Image" robot skill returns the following error message in ARC. I assume this is because the skill has been discontinued. Is there a ChatGPT alternative robot skill I can use instead?
Context:
  • ARC Version: 2026.05.24.00 (running on Windows 10)
  • This is an ARC robot skill that appears to call the OpenAI API (not related to any EZB hardware).
  • I encountered the error while running an ARC project that includes the OpenAI Dall-E Image Skill.
Error log:
Timestamp: 2026-06-11 22:55:08 UTC
OS Version: Microsoft Windows NT 10.0.26200.0
Base Directory: C:\Program Files (x86)\Synthiam Inc\ARC by Synthiam\
=== Exception Information ===
Type: System.Exception
Message: {
 "error": {
   "message": "Missing required parameter: 'model'.",
   "type": "invalid_request_error",
   "param": "model",
   "code": "missing_required_parameter"
HResult: -2146233088
Source: OpenAIDalleImage
TargetSite: Void MoveNext()
StackTrace:
 at OpenAIDalleImage.MainForm.<generateImageFromDescription>d__15.MoveNext() in E:\Documents\SVN\Developer - Controls\In Production\OpenAI Dall-e Image\MY_PROJECT_NAME\MainForm.cs:line 319
--- End of stack trace from previous location where exception was thrown ---
 at System.Runtime.CompilerServices.AsyncMethodBuilderCore.<>c.<ThrowAsync>b__6_0(Object state)
Thanks - looking for confirmation if the skill is discontinued and whether a ChatGPT-style robot skill exists as an alternative.
EZ-B v4/2 robot controller: dual Cortex ARM, Wi-Fi, audio/video, 24 servo/digital ports, I2C/UART, camera and Synthiam ARC control for custom robots
Generate or edit images with OpenAI GPT Image from text or camera frames, with save and programmatic control commands.
ChatGPT conversational AI for ARC robots-configurable personality, memory, image description, script execution, speech and API integration.
The deprecation of the image dalle model was done by OpenAI. An update for the skill is in the works to use other options.
Earlier today the dall-e robot skill was updated. While it appears to no longer use dall-e, there are other models selectable by Open AI.
This works well. I just need to work out how to display the image created. When I save it, the previous image is saved rather than the image just created. It's a matter of timing.
