Is there an older version of the ez_b.dll or the source code available for it?
jjezr
— Edited
TCP Client
— Telnet-like ASCII TCP client for ARC: connect to IP:port, send ASCII, view raw or HEX server responses with local echo
Source code, certainly not. It is commercial software, not open source. Old version, how old do you need, and what function was deprecated that you need? I might have a version of the SDK download sometime last year, but I don't think anything has been removed in newer versions.
I was looking for a version that didn't include the speech or speakjet objects in the dll.
Speech has always been in the DLL as far as I know. Although the EZ-B v3 could not speak itself, EZ-Robot has always supported speech, and so the SDK always supported it.
Ok. Are there any plans to include the ARDrone references in the monoSDK ez_b.dll ?
There are no plans to include ardrone references by ez-robot in a mono version. I would recommend using one of the many c# libraries available for the ar parrot drone.
Here's a good one: https://github.com/ARDrone2Windows/SDK
Thank you both for following up. BTW...EZrobot platform and software is cool to design with.
Something I didn't realize when I was answering. The new Universal Bot SDK is open source. You can download the source code here: https://synthiam.com/Products/ARC
I will take a look at that. Thanks again.
