EZMQTT Broker icon EZMQTT Broker — Local MQTT broker for ARC: host pub/sub messaging on TCP port 1883, relay topics between publisher and subscriber clients. Try it →
New To This ;)
Hi all, I'm new to this forum and new to building robots. Got some inspiration from DJ Sures 1980's Omnibot build. I've got myself a EZ-B v3 control board and an old omnibot but was wondering if there is a way to purchase the rest of the kit or at least the wifi camera for v3? If not any advice on the best servos to use would be appreciated. I have been looking at AS-17 servos and HXT 900s. Thanks for taking the time to read my post and hope to hear from anyone soon;)
Ken.
#33
You are using a lot of the same stuff I threw in to Melvin... so from experience;
The TB6612FNG is fine to use however you need to use an external supply (i.e. don't take the Vm from the EZ-B take it from the battery) for the motors. I have also had some issues with Melvin spinning on powering up, I believe my V3 sets some pins high when initially powered up on occasion, I still need to check it properly though before I can say anything for sure. The TB6612FNG as wired like this works fine on the V3.
The MG-995s I found were browning out my EZ-B when the 2 in the pan/tilt of Melvin's head were being used. I found I needed to add in a regulator and provide them with power (Vcc & Ground) which didn't pass through the EZ-B. I have since made it a standard of mine to provide all servos Vcc and Ground from regulated supplies rather than from the EZ-B (basically only bringing the Signal from the EZ-B, the power comes from the battery via a regulator).
Good luck trying not to do too much at once. Melvin was supposed to be me testing the water... I fell in the deep end very quickly and have been juggling projects ever since.:)
Great, that wiring info for the motor controller is a life saver;):) so the servos should work fine straight from the 6v 4.5 amp battery with a regulator for each one? What do you think of the LM2596 regulator board? Will that do what I want?
Or am I best making my own regulator board rather than purchasing one already assembled?
#36
If it's a 6v battery you wont need a regulator, just power the servos direct from the battery. The MG995s can take 6v without a problem (some reports say 7.4v but I'm not about to check it out just yet).
:) Once again thanks, it would have taken me forever to try and work out the wiring for the motor controller.
#38
It's straight forward enough, there is another forum post about it which might show it a bit clearer. I have it sketched out myself somewhere from when I did Melvin's, if I can find it I'll scan it in as I made it very clear and easy to follow (I needed to, it was the first thing I wired to my EZ-B after 10-15 years without soldering or anything)
That would be brill:)
#40
Here's my scribbles on the controller. Should be pretty self explanatory.
Run out of time tonight (it's now midnight so I need my bed!) but I also found my original sketch version of Melvin's schematic. I'll scan that in tomorrow and pop it up for you.
