SMTP Client icon SMTP Client — Send SMTP email (text or camera images) from ARC robots via ControlCommand; configure SMTP/auth and sender; saves credentials in project. Try it →
France
Microsoft Cognitive Vision Speaking French
Hi, I'm from France. I've tested the Microsoft Cognitive VIsion, it works well, but only with an english description.
How can I configure ARC or the plugin to have french answers ? Thanks for your step by step answer, and sorry for my english ! Regards Stephan
Hi, Thanks for these links but none of them explain how to configure Microsoft Cognitive Vision to format the answer of the description in french langage. I've tried to find an answer on the Microsoft web site but I can't find any langage parameter tips. Thanks for helping me. Regards Stephan
Hey Thanks Ok so the only way is to apply a translation to the $ variable returned by the api Is anybody have an idea ? Perhaps installing a new api in windows but I have no idea of the way to do that Thanks for a y answer Regards Stephan
Hi I am working to integrate the Microsoft translate api in a plugin When i come back from holidays i Will share i think end of august
@Jlucben
A Microsoft translate api plugin would be fantastic, let me know if you need someone to do some testing
I've been looking for a way to translate to Croatian and the Microsoft api sounds perfect
@jlucben Super ! I can help you if U need Where are you from ? Me near Chartres Regards Stephan
Hi I live near Brest I have a first version of translate api integration which is working I only need To integrate the code in an ARC skill plugin I Will do that when I Will come back from my holidays after August 10
Jean luc
Hi jean Luc I'll be on hollidays at Trevou Treguignec between agust 12 and 19 Are you far from there ? Meanwhile I can Guibe any help you need Stephan
