Synbot Plugin icon Synbot Plugin — Synbot plugin for ARC: local Bot Server chatbot integration with SIML dialogs, ControlCommand API, multi-language, learning and emotion support. Try it →
Low Cost Eyeballs For Your Project
Recently stumbled across this web site - www.GlowUniverse.com
that has a novelty item that is a painted eyeball with LEDs installed inside and is designed to be worn on different fingers on your hand. These rings are offered at just over $1 each with shipping. If you use a razor blade and carefully slice open the silicone mold you will have yourself an eyeball to install into your project.
Future project using a pair of these eyeballs.
