SSC-32 Servo Controller icon SSC-32 Servo Controller — ARC integration for SSC-32 servo controllers via PC COM or EZ-B/Arduino UART; maps V0-V31, configurable baud, enables servos in ARC skills. Try it →
Labview 2015 Sdk Integration
Hey,
So I've been working with the EZB SDK with VB C and C++. I got the hang of it and know most of the functions/how to set up. I'm working with some fellow colleagues on integrating the EZB with a feature extraction algorithm written in labview. However, for some reason I cannot reference the EZB.DLL into labview and get started! I know its a .NET type but something tells me it has to do with 32/64-bit compatibility issues. Could this be the case? We do have some labview code that controls an EZ-Rover and it references the dll properly, but that was written in LabVIEW 2013. Do we need to downgrade or change compatibility?
Thanks in advance!
EZ-B is definitely 32-bit, so that could be an issue. Could also be your .NET version. I haven't done anything in LabVIEW in many many years, so can't provide much assistance there, but I do know their customer service is excellent, so you might want to also ask the question in their user forum or even call their tech support.
I see. While on the topic of compatibility, can you tell me what .NET version EZ-B uses? Since I'm running 64-bit systems, I'm guess I need to start running programs in 32-bit compatibility now. Also, if I may digress, can I access the DLL file in some way to make some sort of 64-bit wrapper DLL? As of now, whenever I open EZ_B.dll in VS2015, I only get a strange Icon and Version dropdown (See Image).
Hopefully DJ will jump in. I believe it is now .NET 4.5. That is certainly the framework he recommends users install or re-install when things go wonky, but I know it is backwards compatible, so the DLL may be compiled in something lower. I haven't read the SDK readme file in a while, it might be in there.
I can't answer the wrapper question. Still learning the basics of .NET myself. Not nearly ready to take on that complexity. I only answered at all because I have a passing familiarity with LabView, but really only from playing around with it when National Instruments was one of my customers and I spent some time in their customer service center in Japan. Had some time on my hands, so played with their toys...... (Did you know NI developed Mindstorms for Lego?).
Yes I do know! But thanks for answering the question, helps clarify a good deal.
Thanks!
Also, @anas9011 you should not need a 64bit wrapper because all 32bit binaries are upwards compatible from 64bit runtimes. That being said, if labview (for some strange reason) doesn't like 32bit libraries, i can compile the sdk in 64bit for you
The reason the ez-b is 32 bit is because there is no 64 bit variables used - which would provide no performance improvements. There are execution optimizations with 32 bit executable on a 64 bit system, because the other bits (in some instances) can be used at the same time. So in some cases, a 32 bit runtime is faster (or more optimized) than a 64 bit
Yep, I saw that post, first one I went to:P Actually, I just opened up LabView 2015 32-bit and I keep getting this error (see image), same with 64-bit. I'm downloading LV2013 to see if its some version issue; since we have some LabView VI's written to work with the rover and they reference the EZ_B.dll properly, but they were written in LV2013. I've looked around and tried stuff like this: https://digital.ni.com/public.nsf/allkb/4742EB60B64BE22186257BCE0053B8FD
@DJSures if you could send me a 64-bit library that would be very, very much appreciated.
Mini-solution:
Alright, so I did two things to make this somewhat work:
  1. I put the DLL folder in the same folder as the LabView VI
  2. I installed and ran the 32-bit version for both LV2013 and 2015
  3. I downloaded the latest SDK and ARC update. The above let me read in all the other DLL's except for EZ_B.dll... which is very strange. I'm still trying to reference the EZ_B.dll though, any recommendations? Note that the above did not work with the 64-bit version (as expected).
