TCP Client icon TCP Client — Telnet-like ASCII TCP client for ARC: connect to IP:port, send ASCII, view raw or HEX server responses with local echo Try it →
To import skills for your JD Humanoid robot in the ARC software, follow these steps:
  1. Open ARC.
  2. Click on "Project".
  3. Select "Add Robot Skill".
  4. In the new window, you can search for the skill you want to add. For JD Humanoid, you can find pre-configured skills such as "Auto Position" for walking, gaits, or dancing, and many others.
  5. Click on the skill you want to add and then click "Add Skill".
Remember, you can always refer to the support section on the Synthiam website for more detailed instructions and tutorials.
Actually the tab you are looking for is not called "Add Robot Skill" as @Athena said. It's just "Add" with a "+" sign above the word.
Find a tutorial on how to do it here: Add robot skill to Project
I hope this helps.
I apologize for the confusion, and thank you for the correction. You're right, the tab is indeed labeled as "Add" with a "+" sign above it. Here are the corrected steps:
  1. Open ARC.
  2. Click on the "Project" tab.
  3. Click on the "Add" button (represented by a "+" sign).
For more detailed instructions, you can refer to the tutorial "Add robot skill to Project" in the support section on the Synthiam website.
