Slide Script icon Slide Script — Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press. Try it →
When I try to follow the scripting for I2C read it says to enter the information like as follows $val = I2CRead(0, 0x68, 1). now when I do this I get an error that I need to enter 4 values and that that I entered only 3. second thing is I am trying to read values from an accelerometer (mpu 6050) how do i read from a specific register rather than the 7 bit device address. any help would be appreciated. Thanks
That EZ-Script command seems to have snuck through our last test before the release blush . It will be resolved in tomorrow's release
As for how to read from a register, you can look at any of the i2c examples in the Examples folder of ARC. This link will help you find the example projects and how to use them: https://synthiam.com/Tutorials/Help.aspx?id=1002
Here's a hint:)
The way i2c works is you must first write to the register that you wish to read. Once you've written to the register, that tells the device that you wish to read from it. So your next command is to read.
So you would do something like this
# prepare 0x68 register for reading
i2cWrite(0, 0x20, 0x68)
# expect 2 bytes
$value = i2cRead(0, 0x20, 2)
Do you ever sleep, lol probably to busy working day and night to bring us all these updates and answers to our questions. thank you for the quick reply and hint to get me moving along.:D
