postaldiego
Italy
Helllo, I am working with a JD humanoid and would like to know if it is possible to control the robot remotely (via the Internet) using ARC software on a mobile device?
Related Hardware JD Humanoid
Yes, you can control your JD Humanoid robot remotely using the ARC software on a mobile device. You can do this by using the Remote Control robot skill in ARC. This skill allows you to control your robot over the internet from anywhere in the world.
To use this feature, you will need to have the ARC software installed on both your robot's computer and your mobile device. You can find the ARC software in the Apple App Store or Google Play Store for your mobile device.
Once you have the software installed, you can follow the instructions in the Remote Control robot skill documentation on the Synthiam website to set up remote control for your robot.
Please note that both your robot and your mobile device will need to be connected to the internet for remote control to work.
For more detailed instructions, you can refer to the Remote Control robot skill documentation in the support section of the Synthiam website.
hi postaldiego
save your project in the cloud of ARC . then download the app on your phone or ipad . then you can find your project in the mobile app .
There's a few ways you can control your robot over the internet.
WIFI CLIENT MODE Configure your EZB to connect to the wifi network in Client Mode. You can check the ez-robot website for instructions on doing that. Once it is connected, find the IP address by looking through the DHCP client list in your router, or scanning for the EZB in ARC. With the IP Address, go into the router and configure port forwarding for the ports 23 (ezb) and 24 (camera). Get the Public IP address of your router and connect ARC to that
Use EXOSPHERE Follow the instructions on the Exosphere manual page here: https://synthiam.com/Support/Skills/Remote-Control/Exosphere?id=18753
