Com Port Manager icon Com Port Manager — Displays local PC COM/Serial ports opened by scripts, showing open/closed status (no communication logs); not the EZ-B UART. Try it →
High Power Servo
Hi All.
I understand that this servo does best with 6V. https://www.hobbyking.com/hobbyking/store/__8496__Turnigy_S8166M_Servo_154g_33kg_21sec.html
Can I simply connect the + and - wires from another power source to the servo, and connect the white wire to the EZ-b, or is something more complicated (like a voltage booster) needed?
thanks in advance,
Frank
Why are you doing the 9 volt at all? Do you have something that can only use 9? I would just have a 6 volt battery run everything unless you need 12v for more power to drive motors. In that case use a 12v battery and a 6 volt BEC for the servos. Electrically varied + positive voltages can share a common - ground but you also want to keep your system as simple as possible.
Thanks. There are a couple things that need 12 volts in my setup, a couple that need USB power, some lights that work best at 9V, different power demands of the 2 types of servos-- an unfortunate mix, which the power distribution board helps with.
It sounds like the one ground will work, if I'm interpreting things correctly.
Frank
One ground will. What I suggest is having one power source. 12v then to get 6v use a 6v bec for the your servos and you can use a buck step down adjustable converter to get your regulated 9 volts. Its cheap... Easy and only one battery. Both the BEC and step down converter are found for a few dollars on eBay;) - Josh S
Thanks, Josh!
Frank
