Indoor Positioning System icon Indoor Positioning System — Infrared indoor positioning for ARC robots: dual-camera tracks IR beacon, shows real-time heading, path and EZ-Script navigation variables Try it →
hi sir...i was able to order my ez kit...and immediately i tried to give it power,i saw smoke coming out from the bluetooth transmitter chip and hence i couldnt connect the ez board with my computer..please i need advice on this device because i really need this device to do my project badly..please reply me as soon as possible..is it possible that i repair it,else what is the alternative available
Hello, Please use the Contact Us form to be in contact with someone from support who can help you. You will receive a verification email, please ensure your SPAM/Junk allows EZ-ROBOT.COM emails, and check the spam/junk to ensure we don't end up in there.
If your EZ-B smoked, the customer support who contacts you will require photos of the EZ-B and damaged area:)
since my bluetooth transmitter is burnt,i would like to know whether i could order for a different bluetooth transmitter and also,would i need a special form of configuration with the EZ board..i intend purchasing the bluetooth transmitter from a local shop here..if that is possible,what brand of bluetooth transmitter should i buy..thank you
You can go here and order the BlueSMiRF Class 1 bluetooth and also order the male header to solder to the PCB:
Bluetooth
Do not buy the bluesmirf - Use the Contact Us form and ask to purchase a bluetooth replacement module. A replacement module from us is very cheap.
