— Edited
Hi,
This is my first post so glad to be here. I have a peculiar problem. I'm trying to get going with my EZ-B v4 and I'm noticing that one of my EZ-B's wifi name shows up in my list without any issues but the other one will show up and than disappear and doesn't come back. I also noticed that it does show up in my wifi listing on my Iphone so I know I can get to it but I would just like to be able to get to it via my PC. Has anyone experienced this?
Thanks
In the mean time go into your router's web based program. In the DHCP section you should be able to assign each EZB it's own static IP address. That way each time the EZB hooks up to it the router will recognize it's MAC address and give it the same IP number each time.
If you cant do that with your router then it's time to get a newer router.
EDIT: I se you rebooted and you seem to have fixed the problem. I have a bad feeling the problem will continue. I hope not. If the problem continues have a read through this thread. I was having much of the same problems:
Hooking up to two EAB's
Your router would not affect the device from displaying in the wifi list. The wifi list only displays wifi signals that are detected. At the point of wifi signal discovery, there is no networking/router/dhcp/firewall involved. The wifi networks that are displayed are merely a signal and this process happens entirely unrelated to the router/firewall/dhcp/etc...
So, on that note... if your PC did not detect the ezb wifi signal, i would assume the wifi adapter in the PC has a buggy driver -or- windows is being windows :). My laptop device driver disconnects from my home network at least 2-3 times a day and requires a reboot. Welcome to Microsoft Windows! This is evidently clear when the WiFi device signal is detected by your iPhone but not Windows. That is evidence that the Windows network adapter and/or network device driver was experiencing a temporary malfunction.
The suggested solution? Power the PC down for 5-10 seconds and power back on. A reboot will only restart the operating system and _not_ the hardware. The only way to restart hardware is to power down the PC.
If you wish to diagnose the scenario further, there is a great wifi scanning app available from the FAQ here: http://www.ez-robot.com/uploads/user/DB763BE15E695777689418BE7364E0A3/WifiInfo-635883706528703570.zip
If you run the WiFiInfo included in that zip file, it will display the wifi signals that the adapter is detecting. See if both of your ezb's are displayed in the WiFi Info program.
If the issue turns out to be your computer as DJ has suggested it's still a good idea to set Static IP address for your EZB's in your router. That may save you from other problems.
Please do not make router changes or ip setting changes.
The wifi detection, as previously mentioned, is only the signal. At the point of detecting a signal, there is absolutely no connectivity - which means router/firewall/ip/dhcp/etc have no effect.
Do not change any settings on your computer or firewall. Do not change anything. Do not add static ip address. Do not reboot your router. Do not configure your router. Do not make any changes to anything.
The suggested solution: Power the PC down for 5-10 seconds and power back on. A reboot will only restart the operating system and _not_ the hardware. The only way to restart hardware is to power down the PC.
If you click on your wifi list, you will see WifI networks. When you are viewing those networks, there is no connection to them. There is absolutely no connection occurring to those networks to view their signal.
Just like you can see things in the room in front of you - doesn't mean you are feeling or eating or tasting all those things. You are merely seeing them with your eyes.
The display of WiFi networks is a display of the wifi signals only. There is no connection to them. Without a connection, there is no ip address. And without an ip address, there is no router. And with no router, there is no firewall.... etc
What ever you do... do not make any changes to absolutely anything. The only thing that is happening is your wifi adapter on that windows PC is having issues detecting some wifi signals. There is absolutely nothing you can do to change that other than power down.
Dave, this individual's post has absolutely nothing to do with anything you have experienced. Please do not change your settings Dave. This has zero relation to static ip addresses because there is no connection to even have an ip address. You can have static ip addresses, that's fine - but it has absolutely nothing to do with this conversation because there is no network connection to even have an ip address, let alone static.
The suggested solution for this individual's experience: Power the PC down for 5-10 seconds and power back on. A reboot will only restart the operating system and _not_ the hardware. The only way to restart hardware is to power down the PC.
Good luck arkofthecovenant. Your very lucky to have DJ's assistance. Not too many CEO's give this level of personal care of their customers.
