Websocket Client icon Websocket Client — WebSocket client for ARC: open/send messages, store server responses in a variable, run a response script, and track connection status. Try it →
Hello to all and Happy New Year. I am having an issue. When I turn on my H Bridge it not only runs the motor it is supposed to but it also runs a modified servo that is not connected. If I change ports for the H Bridge control it changes the modified servo that it also controls (sometimes). Is there a solution such as a draw down resister on the modified servo ports? Any help would be greatly appreciated.
Hello Sirlal, Yes, the capacitors did the job. On your other issue the h-bridge is left nutral when you start up EZ-B and only goes to a 0 state when you connect. So the solution is to put a switch on the power supply to the H-Bridge and leave it off until you connect the blue tooth.
