Command Duplicator icon Command Duplicator — Duplicate and synchronize commands from one master EZ-B to multiple slave EZ-Bs for simultaneous, mirrored robot actions. Try it →
Greetings Fellow Robot Builders
Just a quick intro - my name is William and I'm eagerly awaiting my ez-b kit. I have a couple of robot projects in the works that I want to incorporate the ez-b into. Up until now I've been using some Phidgets and Sabertooth motor controllers, tied together with custom code and Roborealm. I think ez-b should make this whole process a lot, well, ez-r.
My first robot, Little Roy, is based on a Lynxmotion A4WD1 v2 kit, with a Fit-PC Slim PC as the brains, Phidget servocontroller and Sabertooth 2x10 motor controller. His main job will be home security and surveillance.
Roy's big brother, Roger, is based on a Jet 3 Ultra power wheelchair. He has a mini-itx Atom PC brain and a Sabertooth 2x60 motor controller. The ez-b will replace the phidgets servocontroller and 8/8/8 IO board. Roger will be patrolling the yard and hopefully pushing a lawnmower to earn his keep.
I will post progress and pictures in the Project Gallery when they're ready.
Thanks, William
Welcome William ! Sounds like you're into very interesting projects. Can't wait so see more of you coming up.
Greetz, PhG
