Sphero Movement Panel icon Sphero Movement Panel — Control Sphero via Bluetooth in ARC. Detects two COM ports (one connects); requires deleting and re-pairing after disconnects or reboots. Try it →
Get Video Ardrone
Greetings. I would apreciate if you could tell me how to view the video, tracking and movement of the ArDrone in code! pls. You have done a wonderfull job with EZ-Robot. Thanks a lot
Thank you:) There are two ways to control the AR Parrot Drone with EZ-Robot
  1. You may use the ARC software to load the AR Parrot Drone Robot Example. Press EXAMPLES within ARC to load the project
  2. Download the EZ-SDK and there are many C# code tutorials to help you build custom software
