SMTP Client icon SMTP Client — Send SMTP email (text or camera images) from ARC robots via ControlCommand; configure SMTP/auth and sender; saves credentials in project. Try it →
Firmware Updater
Noticed that I can't edit the com port in the Fimware updater like you can in ARC my windows assigned COM port is Com 8 apperas on ARC as Com 83 no problem delete the 3 and I'm up and running. Need this feature in the firmware updater though
Also I paired my EZ-B board without adding a pairing code and it pairs just fine then when I run ARC and click the connect button windows requests a pairing code to be entered and then ARC works as normal. Interesting feature might be useful for something security related?
That drop down is meant to be that way:) its to encourage everyone to reinstall If windows screws up the com ports - as usual:(
Tried that re-installed ARC and deleted my EZ-B bluetooth (twice) connection re-paired it and its resolutely stuck on Com83. I will try a few other things but its not done this before
Ok fixed it by deleting another Bluetooth device my GPS then re pairing the EZ-B board. Then I got a normal list of Bluetooth ports for the Firmware updater to connect to :)
