Ezbot Connections To Client Mod
I attempted to switch my ezbot ap mode to client mode. part of the issue is that when attempting to access the web page which use an ip address of 192.196.1.1 my home router which is the same ip address come up in steady. after a few trys of rebooting I get the exbot web page manage to go in client mode the then my bot tells me that it cannot get internet access. so I can access the bot threw the ARC. I reset the bot network connects and its back and forth
any I idea on how to get around this
Once you are in client mode, the IP Address of the EZ-B is no longer 192.168.1.1.
The IP Address of your EZ-B in client mode is assigned by your router.
To find the EZ-B in client mode, use the SCAN button in the connection control -or- look in your router's DHCP client list.
Here is the EZ-B WiFi modes tutorial: https://synthiam.com/Tutorials/Lesson/15?courseId=5
Here is information on how your home network works, and what a CLIENT is and what IP Addresses mean: https://lifehacker.com/5830886/know-your-network-lesson-1-router-hardware-101
yes I when threw ever step possible and read the ezbot lession and video lessions. and can not access connection at the client level. I scan in easy build for that ip address and went in my client network in my router and cannot see that special ip number given to the bot I try turning off every thing I think might get in the way of the connects. nothing.
Does the EZ-B speak and say that it has connected successfully to your network?
What does the speaker say?
when I get into client mod it says it cannot connect to the internet and it says nothing more at that point.
it says everything else except it does not say anything about connected to the network or internet.
I'm sorry, can you clarify? Here is the instruction video. Let me know if you receive the same verbal speech commands from the ez-b when it powers on...
What I need to know is when the EZ-B powers on, what does it speak and say? For example, does it say:
  • I have successfully connected to your network or
  • I am unable to connect to your network
Which one of those two vocal messages does the ez-b speak?
Please watch this tutorial and tell me where your experience differs please.
