UBTECH Alpha Servos UBT-12HC icon UBTECH Alpha Servos UBT-12HC — Control UBTECH Alpha UBT-12HC smart servos via ARC using EZ-B v4/IoTiny UART, assign virtual ports, set baud, custom bits and position mapping. Try it →
Using the i2c is the easiest - because that's two way communication. Otherwise, if you wish to control the Arduino with one way, you can use any of the EZ-B's digital ports and send Serial commands from EZ-Script.
What is it that you're looking to do?
@djsures thanks for the answer, I have board and was just wondering.
j
