DHT11 Temp & Humidity Sensor icon DHT11 Temp & Humidity Sensor — Read DHT11 temperature and humidity on Arduino (signal pin 4) using EZ-Genuino_DTH11_Uno firmware; exposes $Temp and $Humid variables. Try it →
Resolved Resolved by Robot Doc!
Ez-B V4 Wifi Robot Controller
Hello Ez robots community, My introduction: I am new to electronics, basically teaching myself and learning as I go. I made a few simple robot projects and I really enjoyed the process.
I am considering buying a "EZ-B v4 WiFi Robot Controller" for $99.00. I have a question before I make the purchase.
1.Can I use my own servo’s, camera and Ultrasonic Distance Sensor with the EZ-B v4 WiFi Robot Controller?
2.Will using my own parts (servo’s, camera and Ultrasonic Distance Sensor) work with the EZ-B v4 WiFi Robot Controller and the ARC Robot Software?
Thank you in advance for your help.
Yes, most parts that can be used with other microcontrollers will work with the EZB(4). If Windows software can recognize your camera then it will work with the EZB.
The advantage to using the ezrobot camera is it doesn't need to actually wire connection to your computer. And can be used by your phone. That's a good thing:)
Also if you have cheap servos, they may be noisy and cause the high speed processors in the ezb to reset. But that rarely happens - only one time have we seen it. Just a caution:)
Hi Robot-Doc, Thank you for your fast and helpful reply. Robot_hacker
Hi DJ Sures, Thanks for your assistance. Thank you for making robotics Ez and accessible to all. Robot_hacker
