SMTP Client icon SMTP Client — Send SMTP email (text or camera images) from ARC robots via ControlCommand; configure SMTP/auth and sender; saves credentials in project. Try it →
Ez-B V3 Board.. 2Layers?
Is the EZ-B board a two layer board or a multilayer board? I think I need to cut the corners off to fit it in a project i'm working on. I'm worried that I may short out any layers that may between the top & bottom. Probably have to remove the power jack and relocate the Blue led, but it should be do-able. Looks to be two layer! drwass2:)
If you do cut it there is a high chance of breaking a circuit. You can cut it if you want, but it would be solely your responsibility if it was unresponsive after.
No modification to the board is recommended.
I really need to just "round" out the corners a little.
Nothing involving any of the traces. drwass2 sick
Hopfully.you.won't.knick anything , that.would.suck man.
and to answer your question, yes it is a 2 layer board.:)
@skater
Definitely missed that in my response but yes it is. I should know I've built almost 500 of these boards lol.
Lol are you glad solarbotics does it now?
Hmm, I guess to clarify things, Solarbotics isn't a manufacturer of EZ-Bs only a distributor, Colin and others that work directly with EZ-robot to manufacturer the final product (and have been doing a fine job I might add).
If Solarbotics did manufacture EZ-Bs I would be a busy man:)
