3-In-1 IMU icon 3-In-1 IMU — EZ-Robot 3-in-1 IMU driver: accelerometer, gyroscope and compass support for motion sensing, orientation tracking and heading/navigation. Try it →
Ez-b Questions For A Large Stationary Robot Of Sorts
Ez-B Questions For A Large Stationary Robot Of Sorts
Hi all. I've had a good look around the website and can't really find a solid answer for a few questions I have so I'm hoping I can find some safe advice from some experienced EZ-Robot users.
Love the look of the dev kit! I have an UP! Plus printer and lots of experience using it largely for RC flying (aircraft and multirotor parts). I stumbled across the site while procrastinating on thingiverse. Struggling to find justification with the wife to buy a hex robot when she says I have enough hexacopters to go round. A thought occurred...
I'm putting together a man shed as a workshop in the garden, a fair size to work on bigger stuff. It will have mains power, 12v LED rail lighting, a 2Kw heater and a 12,000btu A/C unit (I'll be doing temperature critical fibre glassing work in there). Electronic door locks and actuators, big extract fan etc...
Basically I figure instead of building a robot, why not automate the manshed with the EZ-B, have my own J.A.R.V.I.S. (Of iron man fame) with the use of an MP3 trigger. I could walk in, ask it to warm the place up to 22 deg C and turn on the lighting and extract fan after it closes the doors. All at the same time running security with a servo mounted EZ-wireless camera.
The first question I have, is does the EZ-B have an internal microphone for voice commands, or an option to attach an external Mic? All the videos and tutorials only mention having used the internal mic on a laptop/PC.
My second question, which I guess is slightly more important, this EZ-B doesn't need to be WiFi connected to a computer to run all its functions does it? Again, it may seem obvious but I've yet to see the paragraph or video that explicitly says once the code and instructions are loaded on the EZ-B, it can run autonomously.
Question the third, is there a voice generator section to the software? I.E. Can a word or sentence be written in and the EZ-B (again, without being permanently wifi tethered to a PC) figures out how to voice it (such as with apples "Siri")?
Many thanks in advance to all whom take part in this thread!
CJ
Hey Carlos sorry I'm chiming in late:) , you absolutely can do some home automation with ezb. Things like temp control can be done using a analog input to read your temp and a couple digital pins to trigger relays in your thermostat/heating and ac controller. Most household appliances are pretty simple in the way that they work. Most jobs can be done with a simple automotive grade 30a 12v relay. Lights can be powered on and off easily because a relay can pass through 110v current regardless of the tiny ezb controlling it. I use 5 to control a saltwater fishtank lighting and pump system.
Here's a low budget drawing for your enjoyment I did using pics of things you want to control:). You need the ezb v4 , relays, wire , connectors , solder and iron and tip120 switching transistors to trip the relays. Oh and ofcourse a pc to run it all.:) the acer netbooks and the acer w3 tablet has become a very popular low power choice:)
Sorry apparently I am excessively using the smiley today lol
Thanks for the alternative suggestions Alan. It's more a case that I want to learn the EZ-B software for future actual robot projects. Instead of learning how to program a thousand different products:P.
Wow Jstarne1, 'A' for effort:P. I'm not worried about the switch gear side of things. I'm a domestic and commercial heating, ventilation and mechanical engineer by day. It's the programming side of things that'll slow me down if anything. The door locks and actuator will be air driven. I'm putting an atmosphere controlled 3D printing cabinet in too. Humidity and temperature controlled filtered air. I was going to run the controls from an arduino but tapping into the EZ-B seems easier.
I suppose at this point I'm running out of ports, perhaps the robotic assist arm attached to the ceiling will have to wait (for the jobs when you need three hands, one to hold something, one to hold something else and one to apply glue).
I'll make a list.
  1. MP3 trigger (unless voice commands as DJ suggested earlier can be generated on the attached PC and played through 2. that)
  2. Extract fan
  3. Heater
  4. Room thermistor
  5. A/C
  6. Compressor
  7. Door actuator
  8. Door open/close microswitches (figure I'd do two on one channel with different resistor values)
  9. Security cam Pan (doubt ill need tilt)
  10. Lighting
  11. Door locks
  12. Printing cabinet dehumidifier
  13. Printing cabinet heater
  14. Printing cabinet air circulation
  15. Printing cabinet thermistor
  16. Printing cabinet humidistat
As for the robotic assist arm, I guess it would have at a minimum; 2 axis shoulder 1 axis elbow 3 axis claw (grip, rotate & tilt) And possibly a rail along the top of the shed to traverse the space:P.
So there's another 7 outputs and that's an arm with no sensors.
Anyone know of a relay board that takes a PWM input to control several relays, one at a time or all together:P.
CJ
Dude , EZ Robot makes it easy:) , honestly with ez robot the hard part is physically building your setup , wiring your garage and all those relays ect. Once you have everything connected correctly it's only a matter of assigning a voice command to the actions you want. Most of your setup will be digital pins on or off. I would recommend using a different ezboard for your robot arm project because that will take some tweeking. You will understand what I mean later because we all constantly improve our pet projects and I imagine that will be one of yours. The other items are very straight forward however. All the lights , heater , air conditioning , door lock trigger ect I would have on a single ezboard. The things like temp sensors and door sensors or even motion detection you can utilize the ADC inputs which are for sensors. That way you keep as many digital ports open as possible. You will need to make a project box big enough to house all the relays ect for ezb to connect too and a benchtop power supply. Personally with you doing this much automation you will need a big case and a power supply that is reliable. A computer case with power supply could be a very good choice for you.
I'm not too worried about the switch gear. I have a 12V 20A power supply for the LED's and my lipo charger. I'll get a 5v 10A supply to feed the robot arm, servos and solinoid valves for the air system. I have a wall mounted panel to house it all in which will have manual override switches in case something goes south. I'll have the laptop keyboard & mouse on a pullout tray and the screen mounted in the panel.
Am I right in thinking there is a good stepper motor control board available that works well with the EZ-B? Something that works on a PWM signal (for the robot arm). Thinking getting a second EZ-B might be a wise idea. That way I could do magnetic induction position sensors for the robot arm.
Of all the hairbrained ideas I've come up with over the years I feel this one is genuinely feasible.
CJ
