Ez-B And L298 Motor Control
I have hooked everything up as per your tutorial. My goal was to control 2 motors independently. Currently I can only run the 2 motors simultaneously. I want the choice to run each motor forward or reverse without affecting the other. My speed control is working as required (1 channel controls the speed for both motors) Can anyone send me a diagram on how to achieve this or does this involve scripting. I'm new to this so any help is appreciated.
Also thanks DJ that info will help me too.
EXAMPLES are great they save some time coding,even if a person is great in coding it helps too
Thanks for the quick response. I have been busy with other things so haven't tried the script. Makes sense as to why the script for the robot commands are different than those I required.
