Netherlands
Error On Laptop And Pc, Cant Add Speed Recognition
Hello. when i try to add a speech recogniton, it pops up like this :
ee the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at EZ_B.SpeechSynth.StartListening() at EZ_Builder.UCForms.FormSpeechRecognition.(Object , EventArgs ) at System.Windows.Forms.Form.OnLoad(EventArgs e) at .OnLoad(EventArgs ) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.SetVisibleCore(Boolean value) at System.Windows.Forms.Form.SetVisibleCore(Boolean value) at System.Windows.Forms.Control.Show() at . (Object , EventArgs ) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.235 (RTMGDR.030319-2300) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
EZ-Builder Assembly Version: 2012.12.28.0 Win32 Version: 2012.12.28.00 CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/EZ-Builder/EZ-Builder.exe
System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.235 built by: RTMGDR CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.232 built by: RTMGDR CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
EZ_B Assembly Version: 2012.12.28.0 Win32 Version: 2012.12.28.00 CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/EZ-Builder/EZ_B.DLL
System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Speech Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
FFMPEG Assembly Version: 2012.12.28.0 Win32 Version: CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/EZ-Builder/FFMPEG.DLL
aForge Assembly Version: 2012.12.28.0 Win32 Version: 2012.12.28.00 CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/EZ-Builder/aForge.DLL
System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Web.Services Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
mwwqz2xw Assembly Version: 2012.12.28.0 Win32 Version: 4.0.30319.232 built by: RTMGDR CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Are you using windows 7 or higher?
Netherlands
I have 2 Computers at the same time. On both they give the error. 1 is a Laptop with Vista. the other is a PC with XP on it.
Yet both have trouble starting the 'ARC Speach Recognition. , it crashes on both '
Yet, on the other side, if i run the 'sound servo' button, it moves on sound heard..
Can you run Speech Recognition inVista outside of EZB? Meaning have you gone through Control Panel and actually started it up, setup your microphone and trained the software to your voice? You may want to try it this way if for no other reason to see if it's actually working on your computer. There are thousands sites on the web that will walk you through this. A quick Google search by me just now found this little article:
www.microsoft.com/enable/products/windowsvista/speech.aspx
When troubleshooting it's best to start at the source. I cant count how many times I've found my trouble has been that something was not plugged in or something stupid like that. My Great Grandfather always said "If you don't know where to start, always start at the beginning".
Good Luck, Dave Schulpius
Netherlands
Ooo, did not know that voice recognation came with Vista. I thought it was a feature that came with the Software of Ez-Robot..
Thank you
Ya, EZB uses Windows, ARC and your computer for most of it's amazing tricks. Let us know how it goes. cool
Netherlands
Aparantly Voice Recognition is not available for my language (dutch on vista)
I wish i could fool the voicerecognitiontool my language is english, soo it would atleast would run...
Dutch is a very cool language. I wonder if you upgrade to a newer version of windows like Win 7 Dutch would be supported? Then you'd also need to see if your computer could run Win 7.
Netherlands
heh, i dont need dutch to be supported. i'm very comfortable with english.
I just wish i could fool the voice program that my language is english.
Maybe i can download a language pack do-over or something..
I have little experience with Vista but can you not select a language from a drop down menu in Advanced Speech Options? There is a topic about Speech Recognition not working only a couple of days old, in it are some screen shots of my Win 7 dialogue for Speech Recognition, is Vista similar?
Netherlands
Voice for Dutch is not supported in Vista.
You cant get it for Vista for Dutch.
If you install your system with Dutch Vista, it automatically tries to load the Dutch Version first. And bugs out on that.
If there is a 'language' setting. its prolly after this error..
Netherlands
I can download a free online like 'http://www.e-speaking.com/' for instance.
is there a 3th party voice which will work with ARC?
ARC uses the Windows Speech Recognition settings, library etc. so I doubt a third party software would work.
Looking at e-speaking, it uses Microsoft's SAPI interface too which would mean it wouldn't work for you either.
