Live Stream Broadcast icon Live Stream Broadcast — Broadcast live audio and video from ARC camera to the web via HLS; cross-browser streaming. Requires router configuration for external access. Try it →
I'm a newbie to the forum and just in the planning stage ( and gathering parts) for the OmniBot conversion. D.J. calls for a QR111D edge detectors. I can"t seem to find one online. Anyone know if there is an equivilent part (w/part number) available? Will any of the detectors from solorbotics work? Thanks in advance.
Hey Lostcreekstation Welcome to the forums! I hope you can find losts of help and hints here.
I believe DJ probably ment this sensor which is called the QRD1114 and is available at Solarbotics, hope that helps!
Netherlands
Hi,
Could you use that sensor as a cheap version for a IR range sensor? I'm looking for a cheap range sensor... Weird enough my ez-b gets a time-out when I try to use a pingsensor in ARC even when it's not connected... And that doesn't happen with IR sensor so I'd figure that's the way to go.
The IR sensor won't give you a very high resolution. Which ultrasonic ping sensor are you using? And by time-out, do you mean the EZ-B disconnects when you attempt to use it?
the QRD1114 isn't a very strong IR. You can get about 2-3 inches of range with it, if you use a very sensitive resistor. I forgot what value I used. I played with a few and tried a variety of ranges.
Here's a great link on the QRD1114 schematic and datasheet: QRd1114 IR Sensor Schematic
Netherlands
I get the time out when I atempt to use a ping sensor. The blue led turns off and I get:
Comm Err: The operation has timed out. (Expect Response: True, Rcv: 0)
I think it's still connected as the red led of the bluetooth module isn't blinking, it's solid when it happens. Also I'm using a HC-SR04, but I get the time out even when it's not pluged in...
Oh while I'm at it, since the last update, the 2011.10.26.00 release. With every script I start I get:
Script Error: Index was outside the bounds of the array.
I also get it when the script stops, but strangly enough everything is working just fine, except for the ping sensor. Befor the update I didn't get that error and I'm still using the same script.
A peace of script: 0.servo(d0,20) 0.servo(d1,20) sleep(500) 0.servo(d1,18) 0.servo(d0,22)
My robot is functioning as I wanted it to, so... I'm doing somthing wrong or is it a bug of some sort.
Interesting... Very very interesting. I can't really understand why that would happen. Since v13 is a complete re-write of the firmware, maybe it will work for you again shrug
Do the pins that the HC-SR04 was plugged into work? Have you tried configuring other pins for the HC-SR04 and see if it still disconnects? Maybe there is a short on the board for those 2 pins, or one of them. I'm not really sure! That's an interesting one.
As for the script error. I've never seen that and it doesn't give me that error with my version. But my version is for v13, so I can't try it with the old one because I no longer have it.
As of tomorrow, those troubles I guess will be resolved:)
Netherlands
DUDE... EVERYTHING...
IT's all fixed!! From now on I will worship you like a GOD, it's even working better than before. Eventhough I had to re-write all my scripts it was definitly worth it! The ping sensor works and I'am not getting any script errors anymore!
You even fixed the problem that if I moved the stick of a joy-stick diagonal that my motors kept running and wouldn't stop anymore. But now it does!
Thanks DJ, the update fixed everything and made the things I had work better.
:) I'm very glad you like it! You really make me smile dude!
