Hi,
Where can i find the last version of the dynamixel plugin source code in C# ?
francois
Smart Variable Watcher
— Efficient ARC Variable Watcher - lower CPU for large projects; slow initial array render but faster updates; shows name, type, value, length
In the dynamixel plugin description: https://synthiam.com/redirect/legacy?table=plugin&id=39
The same place where you installed the plugin...
I have download this source code. but I think is not not the last version. There is "Baud Rate" text editor in the plugin configuration window but not in the configuration form in the source code project. when i compile the project and replace the plugin dynamixel.dll by the compiled dll the plugin does not work.
sorry my english is not very good
