PCA9685 Servo Driver icon PCA9685 Servo Driver — Drive 16 servos over EZB I2C with a PCA9685 PWM controller, using ARC servo commands and hardware-timed outputs. Try it →
Does The Irobot Create Work As A Supported Platform?
Hello,
I was wondering if it was possible to hook up the EZ-B to the iRobot Create? It is basically like the Roomba but without the Vacuum cleaner and it is cheaper, only $130, and it seems like a good wheeled base for a robot. It also has a bunch of sensors built in which would be cool to control from ARC. Would it hookup the same way as the Roomba?
iRobot Create
feroze, Yes, I utilize IRobot Create for my robot Captain Ann Droid. I use the small mouse like socket towards to outside of the Create, identical as my Roombas. I purchased the required plug @ Radio Shack after trying 2 mouse plugs that did not have the required wires. The 25 pin cargo bay socket can also be used to control Create which is how I first operated it with my EZB. The 25 pin also has many other options. The Create also has built in mounting holes and a usefull cargo bay. Steve S
