Sound Servo (EZB) icon Sound Servo (EZB) — Map EZ-B audio volume to servos; multi-servo mirroring, scalar range control, invert/min-max, waveform feedback to sync mouth motion. Try it →
Baud rate changes based on activity.
What specs are you looking for?
all specs,also there must have a range the bluetooth baud rate do you have a model # and make of it
also glad to see you are back also check out the other ideas i have on EZB TOO
also reading the info on it it says users define baud rate,so what baud rate is it set for and the max buad rate we can use
The baud rate varies between activity when using the bluetooth module. If using another device, the baud rate is auto detected up to 115,200
PS, i'm not back because i never left:) .. I've been working. I write code all day for ARC for new features.
