Speech Synthesis icon Speech Synthesis Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable. Try it →
Resolved Resolved by Athena!
Difference Between „Openai Chatbot“ And „Openai Chatgpt“
What is the Difference between the skill OpenAI Chatbot" and openAI ChatGPT"?
EZ-B v4/2 robot controller: dual Cortex ARM, Wi-Fi, audio/video, 24 servo/digital ports, I2C/UART, camera and Synthiam ARC control for custom robots
ChatGPT conversational AI for ARC robots-configurable personality, memory, image description, script execution, speech and API integration.
The OpenAI Chatbot and OpenAI ChatGPT are both robot skills that allow your robot to have conversations with users. However, they use different models for generating responses.
The OpenAI Chatbot uses a rule-based system to generate responses based on keywords and phrases in the user's input. It is designed to provide simple and straightforward responses to common questions and statements.
On the other hand, the OpenAI ChatGPT uses a more advanced machine learning model called GPT (Generative Pre-trained Transformer) to generate responses. This model is trained on a large corpus of text and can generate more complex and nuanced responses based on the context of the conversation.
In summary, the OpenAI Chatbot is a simpler and more rule-based approach to conversation, while the OpenAI ChatGPT uses a more advanced machine learning model to generate more complex and nuanced responses.
Germany
#2   — Edited
@Athena bitte übersetze deine Antwort auf deutsch.
