Get Line Containing From Array icon Get Line Containing From Array — Adds GetLineContainingFromArray() ez-script function to return the first array item that contains specified text, simplifying substring searches. Try it →
Italy
Could Not Connect On Windows 10 Ez V3
Hi guys
I just updated windows 8.1 to windows 10 and I now got this error on ARC: 8/15/2015 1:44 AM - Disconnected 8/15/2015 1:44 AM - Attempting connection on COM3 8/15/2015 1:44 AM - Connection Failed: System.TimeoutException: Timeout di scrittura. in System.IO.Ports.SerialStream.Write(Byte[] array, Int32 offset, Int32 count, Int32 timeout) in System.IO.Ports.SerialPort.Write(Byte[] buffer, Int32 offset, Int32 count) in EZ_B.EZB.Connect(String hostname, Int32 baudRate) 8/15/2015 1:44 AM - Disconnected
Is this windows 10 related or am I missing some drivers?
Nevermind: upgrading Windows changed the default port for the Ez. Moved to COM4 and now working great
